crack in block
I used a Dremel tool to clean the crack a bit more and used A LOT of JB Weld and held it in place with a bit of masking tape......7 years so far.
I had a crack near the front of the block and used JB weld high heat.. So far holding well.. Like real welding, getting the area clean and to pure metal is 90% of the work.
Lee, before you do anything, i'd contact the engine re-builder and ask for a full / partial refund. You probably wont get any, but it doesn't hurt to try.
Then do as everyone is saying and "V" the crack, clean it, and use regular JB weld.
It won't set up very fast and tends to want to sag and run out. Just keep putting it back in there until it starts to stiffen up some. Then take some 80grit sand paper and place the "grit" side against the epoxy and hold in place until hard. The sand paper will give you a texture to match the casting marks on the block.
I did this exact repair as yours on a '29 Tudor I sold a while back, and you could not even tell there was ever a crack.
Good luck. Dave.
AND,let that professional know he rebuilt a cracked block!!
Never ***-ume anything !
Didn't leak for 1100 miles.
Perhaps it was not cracked when it was rebuilt.
Maby it was magnafluxed and was OK.
Things can happen during installation.
Did it freeze up? Overheat ?
This cast iron is 86 years old !
This is a common place for a crack. Usually caused by freezing.
I have had very good luck when an engine is in the car using K W Ceramic Block Seal. Follow the directions exactly and I have an old radiator I temporarily install as it may partially coat the inside of a good radiator. Thru the years, I have use it many times and most of the time I have had good results.
If for some reason it does not work, you can always try J B Weld or pinning etc.
If the engine was out of the car and on the stand, I may take a different approach but in the car, I would first try K W Ceramic Block Seal.
Again, JMO
Chris W.
Really? You should re-read my post. Do you rebuild engines by-chance?
It seems to be an old freeze crack that has opened up. I would use a Dremel with a small diameter bit to clean the crack, and then fill it with JB Weld. I've read several success stories using this method, and if it did fail, then you can always still drill, thread and pin it.
I had a T head with a nasty 5 inch long crack across the top. V'd it out a bit, JB welded it, then when cured used a grinder and then sander to shape it. After it was painted it was impossible to see and never leaked again.
Thanks to everyone! It looks like JB weld is the first course of action. I will re-post if it doesn't work. As usual Tom W., I believe you are spot on, but we will never know and it doesn't really matter at this point- just want to drive my A. : )
Yes Really !
I do re-build engines, but not by-chance. I use precision.
Perhaps you should ask your "professional rebuilder" if he magnafluxed the block.....
Maybe he did & just didn't see it, in such an out of the way place.
Have you ever made a mistake?--------I've made MANY:D:D:D:D!
Bill W.
Bill W.
Yes Bill I have however, this is not "in such an out of the way place" and is one of the first places an "experienced rebuilder" should check for cracks.
As was said by "Tbirdbird" in comment # 10..." common location when antifreeze is overlooked ".....
GOOD point, Mike, I would have been ticked off, also. It doesn't seem common to see freeze cracks here, only hot cracks!
Bill W.
