Dyna
My 48 Merc is acting up. Went for a good two hour drive on Thursday with no issues. Went to start it today and heard an awful noise. Sounded like intermittent metal on metal ticking. Noise starts as soon as any pressure is put on the clutch pedal, stops when taking pressure off pedal. Engine and ****** have been re-built. I am afraid to try and put it in gear. Does this sound like a throw out bearing problem? I notice that there is a zerc fitting on the shaft that goes into the bell housing that is rotated by the clutch pedal, would greasing that be of any help? Can a throw out bearing be lubed through the inspection cover on the top of the bell housing? I will pull the floor out tomorrow, any thoughts as to what I should be looking for?
Thanks for your input.
Greg
Greg
