Correct 33-34 roadster snaps
Ed Solari
On the door side are snaps(male) for the side curtains. Are these the 3/8 or 5/8 screw stud to attach to the wood below the door skin??? or are they snaps that attach only to the metal??? Is the correct supplier LB???
Thank you for you help
Ed, They are female,spring loaded and when pushed in spread out which holds them in.LB has them and the tool.
Ed, buy the "setting tool" when you order the correct female receiver/snap. LB has the tool also.
Here's one of the female fasteners installed.
