E Ed Solari Senior Member Mar 1, 2016 #1 On the door side are snaps(male) for the side curtains. Are these the 3/8 or 5/8 screw stud to attach to the wood below the door skin??? or are they snaps that attach only to the metal??? Is the correct supplier LB??? Thank you for you help
deuce lover Well-known member Mar 1, 2016 #2 Ed, They are female,spring loaded and when pushed in spread out which holds them in.LB has them and the tool.
bluardun Senior Member Mar 1, 2016 #3 Ed, buy the "setting tool" when you order the correct female receiver/snap. LB has the tool also.
DavidG Well-known member Mar 1, 2016 #4 Here's one of the female fasteners installed. Attachments Book photos 017.jpg 95.1 KB · Views: 20
