Do you mean the engine is idling, or not running at all? If the ignition is on, and the engine is not turning, the points might be constantly open, in which case no current will be flowing through the coil, or they might be constantly closed, in which case the coil gets maybe twice the normal amount of current flowing through it. In that case, it would definitely get pretty warm.
Doug
