Coil choice
Ricosan
I am trying to find a coil for my flathead.
I have a 1933 engine that was rebuilt by H&H Flatheads. It has aftermarket aluminum heads, two stromberg 97s carburetors, a slightly lopey cam (I don’t know which one) and Mallory dual point distributor 2572101.
I currently have an all black generic coil with a ballast resistor between the ignition and the coil. It has been converted to 12 volt negative ground.
Question; what coil would you recommend? Should I stay with the ballast resistor in line system or eliminate it and go with a coil that has a built in resistor. I am confused when I look at the specs of the coils. Resistance is all over the board. From .07 ohms to over 8 ohms.
Richard
Thanks Corvette, that was a good post. I like the Bosch and I would buy one but no one has any.
I’ve read that the “Beru” coil is the replacement coil for the Bosch blue 00012. Anyone know anything about this coil?
Richard
I have always heard nothing but praise for the Bosch blue coils. All my cars had original Ford coils or Mallorys and they were great too. I had friends with VW baja bugs in the 1970s and they all ran those Bosch coils for off roading where they got shaken around a lot. They were supposed to the most durable coils.
Richard
I've used many of the Beru coils with no problems. Actually they are less expensive than the Bosch
A plain old 6v coil with a 2-ohm power resistor works just fine on 12v with points. Don't even need a bypass..Simple...
Richard
I have a used Bosch blue coil I will sell you for what I paid. I bought it from someone on here or the HAMB. I never used it because I went with a Stromberg efire and Petronix flamethrower 1.5 ohm. Message me if interested.
491040
Thanks for all the information and advice. I’ve decided to keep the inline ballast resistor and install a Mallory with 1.4 ohms resistance.
Richard
