jimvette59
It seems that you can't lubricate the clutch throw-out bearing in service. If it ever starts acting up you have to remove the rear end, transmission and bell-housing just to get to it. Not very smart "maintainability" design on Henry's part for such a critical item as this is.
Note apparently conflicting service literature:....
The large vintage-looking "MODEL A LUBRICATION CHART" by Don Walker points to the hand access cover on the bell housing as the location for lubricating the clutch thrust bearing via the adjacent grease fitting on the slider (hub) every 2000 miles.
BUT - Les Andrews' "MODEL A FORD MECHANIC'S HANDBOOK, VOL 1" clearly states that the grease fitting on the thrust bearing slider DOES NOT lubricate the bearing, only the slider (page 1-320).
Trusting Les Andrews, I suspect that the LUBE CHART is in error.
So is the throw-out bearing "permanently lubricated" and "never" needs greasing/packing?
Approximately how many miles should this bearing last?
Has anyone had success in getting grease into this bearing as a preventative servicing measure without having to tear the whole drive train apart??
Insights appreciated.
Earle
P.S. Remember - standing at a red light with the clutch pedal fully depressed is directly loading and spinning the throw-out bearing and using up its precious service life! I have recently changed my old habbit to stop doing this - even if it takes a second or two longer to get into first gear when the light turns green.
If I remember correctly there is a early ford with a grease fitting out side of the bell housing and a line going to the T/B. ????
