Clutch Release Shaft Position Help Please
31 coupe
Hi all, I'm after your help again please.
I'm looking for the vertical distance between the input shaft centerline and the clutch release shaft centerline please. I'm building a custom bellhousing and want to get the TO fork at the correct height.
Thanks in advance, GB.
Can anyone help please?
If you have a >1948 gearbox in the shop an accurate tape measure dimension is all I'm after, C/L to C/L.
Thanks, GB.
3 1/4"... and I took a bit of care, this is real close- if anything, you could add 1/64" to this
Karl
Thank you very much Karl,
That is exactly what I needed. I'm planning a shopping trip to the US later in the year and will get a new fork from Mac's but I want to get the bellhousing underway now.
Best regards, GB.
