I have installed a 39-40 brake / clutch pedal assy. on a 37 ford. I am using the 37 trans. with the stock lever on the clutch cross shaft. The clutch pushrod from the pedal assy. to the lever is offset. Will going to a 39 clutch pushrod and cross shaft lever correct the offset problem? Thanks
