i installed a new clutch disc, throw out bearing and put a new pilot bearing
in my model a . It grinds when the motor is running when you try to put it in gear. Could this mean the clutch disc is in wrong or what?
I just finished 1yr and a half restoring the car from ground up frame off restoration. Went to take off for the first time and found this problem.
Kind of took the wind out of the sail !!!
ANY HELP WOULD BE APPRICIATED B-4 I START TAKING OUT THE TRANS!
HOWARD
HOWARD
