JayJay, thank you very much for your explanation and agree I will need to work the 2nd part of the adjustment. So if I understand correctly, after I adjust the pedal to 1 inch of free play, the 2nd part involves removing the clevis pin and raising the arm to where the throw out bearing just off the pressure plate and then reattach the clevis pin. Am I on target?
Sorry, I'm having difficulty following your description. You cannot properly adjust the free play without removing the clevis pin. There is only one place to make that adjustment. Here's how I adjust the free play:
1. Lash your clutch pedal in the full up position. I use a bungee cord to the seat frame to do this. I'd also suggest that you remove the upper floorboard so you have more room and visual.
2. Remove the cotter pin from the clevis that connects the clutch adjusting rod (the fork-shaped thing) to the clutch arm. You won't reinsert the cotter pin until the end.
3. Remove the clevis pin. You will likely have to push up on the clutch arm to get enough slack to push out the clevis. That will leave the clutch adjusting rod threaded into the trunnion nut (the round thing about 5/8" diameter and maybe an inch or so long that goes into the U-shaped saddle on the clutch pedal) disconnected from the clutch arm and dangling from the clutch pedal. You adjust the free play by screwing this adjusting arm in and out of the trunnion nut.
4. With the adjusting arm disconnected (clevis out), push up on the clutch arm until it stops. This is the #1 free play I described earlier.
5. Keep pushing up on the clutch arm (much harder now) until the second time it stops. This is the #2 free play I described.
6. Take note of the position of the clutch arm when it is somewhere between #1 and #2. W
th the clutch pedal in the full upright position, screw the adjusting arm in or out of the trunnion nut so that the holes in the adjusting arm saddle line will up with the hole in the clutch arm when the clutch arm is re-raised to the position you noted earlier. Push the clutch arm up into the adjustment arm saddle and insert the clevis pin. This is the part that usually requires much strength, perhaps an extra set of hands, and much cussing. Beer helps.
7. Remove the bungee and check the pedal free play. If there is over 1" of free play in the pedal, push up on the clutch arm to remove tension, remove the clevis, drop the clutch arm out of the adjusting arm saddle, and screw in the adjusting rod. Reinsert the clevis (more strength, extra hands, cussing and beer). If there is less than 1", do this but back out the adjusting rod. Try only moving the adjusting rod a turn or so at a time, with enough repetitions you will find yourself getting closer. You will likely be about mid-travel on the adjusting rod.
8. When you are satisfied, insert a new cotter pin into the clevis.
