Zeke...PA
On an 8BA with the 9 1/2" clutch is there a 9 1/2" clutch disc with large spline ? Want to use on my 37 transmission with a truck bellhousing. Will the 9 1/2" long type pressure plate work, looks like fingers are on a slightly smaller radius for the throw out bearing it also had a smaller spline disc. Will the 10" pressure plate bolt to the 8BA flywheel that had a 9 1/2" p/p ?
It originally came with an early flywheel, 9" long clutch & pressure plate and with starter plate cut out, it also had a spacer between the crankshaft and flywheel.
Thanks for any help, Zeke
