I have adjusted the clutch lever/yoke on this 1935 Ford trany as far as it can be done. But the clutch does not fully disengage the pressure plate with the clutch fully depressed. There is a cover on the trany above the gear shift lever that exposes the pressure plate adjustments. How do I go about adjusting these???
thanks,
Chuck
thanks,
Chuck
