When I was a kid, I had a 1972 MonteCarlo. Those were all the rage. Then I talked with a guy at work about 40 yrs old. Gary was quite knowledgable about cars, and used parts. He told me "don't get one. they draw dampness for some reason, and your car eventually will not start". Sure it's cool, but only put it on for show. Reliability. I asked around, and heard the same story from other people.
Picture gluing a clear thread together over and over. That is what 3D printing would look like. The solution type of 3D printer might work. But who's going to program it? To make a few it would be easy to make a mold and cast it.
Well, you can use it to diagnose when the capacitor starts to go bad.The clear cap or cutaway cap are really just for curiosity, nothing diagnostic can really be done with them. I guess you could see if the distributor body had a short in it though.
Focusing the timing light on the kit distributor cap permits observation of the rotor, cam, points, and electromechanical operation under running conditions. This kit can identify arcing at advance and retard positions. The rotor brass contact positions and arcing can be seen at retard, intermediate, and full advance positions. There should be no rotor contact with the distributor contacts; motion to each side at the extremes of retard and advance should be equal. Cam wobble and point motion can also be observed for uniformity of action. Internal arcing to ground or adjacent distributor contacts can also now be observed.
Danke für Dein Lob! -I admire this kind of commitment.
<snip>
Creating a file for 3-D part printing is too expansiv.
<snip>
Hi',
in the meantime, I have tested the transparent cover several times. Great disappointment was that the spark jumps are very mild and barely visible.
Joy was to recognize by it, that the condenser and the plugs resistors are in order.
