Do you have the original sleeves? They should have two small bolts on each end; the bolts have square heads, and are less than 1/4" I think. The sleeves are about 3/4" long if you are going to make them, could make them on a lathe and drill the centres to accomodate the rods. A bit of work, but I don't know if they are available. Byron W.
