Rembrant
Hey guys,
I'm wanting to check the oil pressure on my '52 flathead, and I see there are two senders or a sender and a switch at the back of the block on the driver's side. There's a single wire sensor mounted in the vertical position, and a 2 wire switch? mounted in the horizontal position. Can anybody confirm for me that they are a sender and a switch? And where would I install my own oil pressure sensor so I can check this thing? Are the ports 1/8" NPT or 1/4", or other?
Also, what is a reasonable oil pressure to be looking for hot or cold?
Thanks all.
Thanks all.
