I know there have been several messages on fixing a car that has a lean to it. It seems like most say to reverse the rear spring. I did just that yesterday and the lean is as bad or worse in the same direction as before reversing it. The spring is an original spring I dismantled, sandblasted, applied Slip Plate, reassembled and painted. I am sure the spring retaining bolt is in the square hole in the rear crossmember, I don't believe the frame is bent or warped. I am at a dead-end as to want to do to fix the approximate 1" to 1 1/4" lean to the drivers side (measured from the outside of the bumperettes to the floor). Does anyone have a method that might fix the lean? BTW, the front spring is new, so I don't see how that could contribute to the lean, besides the front looks OK.
Rusty Nelson
Rusty Nelson
