vern hodgson
Ok, so the frame number on my vehicle is W2468, the W indicates Winnipeg, what do the numbers tell me?
I believe that is the production number from that plant. Did you find that under the front seat?
I found T2229 in that same spot - Toronto assembly. The Engine number (May 1930) is the best clue I have to when that body came down the line, but who knows how far out that may be. With any luck you'll find some more Winnipeg assembly cars that may help
Good to know, be nice if we could get Canadian owners to submit their data and compile a rough database.
Vern, The attached is interesting.
https://www.mafca.com/downloads/Technical/Assembly Plants Body Number.pdf
No I don't. I am in FL right now but will be back home in Canada next week. I will look in my file on my car to see if I have any other infoYes I have seen that article, do you know the date he posted? Sadly there is no correlation from number to mfg. dates.
Hello Vern,
Great talking with you last night on the phone about these body plant numbers. I will check my logs like I promised last night and get back to you. I would also like to get the numbers from your 1929 Special Coupe.
Regards,
Dave
Hello Vern,
Regards,
Dave
