Jack 34pu
The cam out of my '50 Merc block has a slight grove or scratch at the most rear bearing surface. It is as though a piece of grit made the circlular mark at the very edge. If polished, is it still usable? The most worn lobe measures within .0004 of the rest. That seems pretty good to me. What do you say? Also, if usable, can i use a soft, fine brass wire wheel to clean up between lobes and bearings?
