Yes I have an after market fluid style as a reference. It reads 10-15 PSI at warm-hot idle, which is about right for a 40 Lb pump.
I suspect that it's the sender as the needle goes past full scale with the engine off, then drops down.
What kind of sender should I try to find - get?
Sent from my LM-V405 using Tapatalk
