1930.68B
We are ready to order the upholstery for a 1930 Cabriolet. One of the questions the upholstery supplier ask is the length and height of the doors. The length of both doors are the same but they a 1/4" longer at the top than at the bottom. Is this typical ?? If not, should we use the shorter dimension so the panel won't hang over the door at the bottom?
Where would the correct place be to measure the height of the door. The finished body surface at the rear of the door or to the sheet metal panel were the door handle and window is mounted?
Thanks
Thanks
