A little off the topic at hand, but I remember in shop class being taught how to figure out displacement. the equation was Bore (times) Stroke (times) number of cylinders (times) Pi (3.1416). That would make sense for say, a ford 302. 4X3X8X3.1416 = 301.59.
If you try it for the above Flathead, 3.375 X 4.125 X 8 X 3.1416 = 349.89.
You guys are saying 296". What gives?
Pi is to figure the circumference of the cylinder bore (radius sqared X Pi). Multiply that by the stroke length gives the volume of the cylinder. Mulitply that by the number of cylinders for total volume displacement.
There are other ways it can be done that work but then most things in mathematics have more than one way to find the same answer.
The reason greenmonster's numbers worked out for the 302 cu. in. example is because in the formula R sq. X bore, etc. the bore is 4", hence 2 X 2 = 4
Ah, cool. Weird how it works one way for some but not for others. I should have prefaced by saying I'm terrible at math.
It's because a 302 has a 4 inch bore!!! 2 pi r = area 2 X 2 = 4 so it works ether way, but only for a 4 inch bore.
Edit: Little late to the show on this one!!!
