Recent full engine overhaul running great untill 9/18/11, started burning points. I have 6 volt, positive ground, starts within 1/2 turn when points not burned. Generator is putting out 6.4 volts idle or when reved. This morning I was at 6.4 volts, reved engine and charging whent to 8.11. After we used emeroy cloth on points and installed a new 6 volt coil, charging is constant at 6.4 to 6.5 volts, with lights turned on, voltage drobs to 6.3. I have modern distributor using 1959 to 1974 ford standard points.
Any and all help why I am burning points, or what to look at will help and be appreciated
Thank you
25 TA
Thank you
25 TA
