Burning Points
Reread his post. He already changed out the coil with a new 6 volt coil. He doesn't say if he's still burning points after he changed it. His voltage is within an acceptable range for the points of 6-8 volts which should rule out high voltage point burning. At this point since he's replaced the coil he might as well replace the condenser.
