Brushing Nickel plating
wrndln
I have several nickel plated items like instrument panels and gear shift levers used on 28/29 vehicles. Currently they are bright nickel finished. I would like to give the parts a "brushed" finish like original. I sure don't want to ruin them attempting to "brush" finish them in a clueless way. I have heard that using Scotch-Brite pads of a certain type (maybe grey or red) can be used to provide the "brushed" finish. Can anyone provide a good method to give the parts a "brushed" finish, to look like they were originally? BTW, are the spark and gas lever handles "brushed"? I don't think they were originally finished that way, but I am not sure.
Thanks
Rusty Nelson
I use gray scotchbrite pads with a light oil lubricant to create a “Butler” finish from bright nickel. Don’t press hard, you can always do more but you can’t go back. Check the Restoration Guidelines and Judging Standards to verify which direction the grain of the finish is supposed to go.
I believe the spark and throttle levers are bright. RG&JS will tell you, I seem to have misplaced my copy.
Let me know if you want some pix on how mine turned out, will have to be later this week.
Rusty, I use gray Scotchbrite pads, and I use my honing tank oil since it flushes away the plating debris. This is not hard to do, but the key is to do it in the correct grain orientation. Light, long strokes with even pressure is all that is required.
Maybe use a plastic tote with a lid, and then add Kerosene or light oil to soak your scuffing pads in. Do your pieces over the top of the tote.
Thanks to all, especially Brent for the helpful responses. I would assume that the gearshift shaft would have the "brush" marks perpendicular to the shaft - i.e. cross-ways - correct? I believe the brush marks should be horizontal for the instrument panel - correct?
Rusty
Rusty
Check the RG&JS for the correct grain direction. I know it's specified for the gearshift lever (but I don't remember which way it is!). Unfortunately my copy of the RG&JS got mislaid so I can't look it up for you :(.
JayJay,
I looked in my JG's and found the brush marks are horizontal when the lever is installed. I couldn't find the instrument panel direction, but I am pretty certain they are horizontal, too.
Again, thanks for the help
Rusty
JayJay,
I looked in my JG's and found the brush marks are horizontal then the lever is installed. I couldn't find the instrument panel direction, but I am pretty certain they are horizontal, too.
Rusty
And the cap at the bottom of the shift lever stays bright. Also, on the brake lever, the handle is bright and the shaft is Butler.
JayJay,
Thanks for the clarification. I knew about the bright nickel bell at the bottom of the shift lever, but I forgot about the emergency brake lever.
Rusty
When I set out to "Butlerize" my bright newly-plated parts I did not really have a good example of how much I should knock down the brightness. I did not have really good originals to work from: my gearshift and e-brake handle had been painted black to hide the chipping plating and rust spots, and the instrument panel was likewise flaking. So I made a decision that I would knock off enough sheen to be noticable, and take it farther if I didn't like it.
I also had to decide how to do it. Light fine wire wheel, rotary wheel, what? I got a clue from the RG&JS that the striations on the shift lever were circumferential (not long axis), which indicated to me that the "Butler" finish was likely applied by hand using some sort of abrasive sheet. Brent in 10-uh-C clinched it in a post some months ago when he described how he does it with gray Scotchbrite pads and light oil (as he describes above). So I decided that's what I'd do.
I think I used the Norton honing oil that I use on my oilstones for sharpening chisels, but I believe any light oil (say 3-in-1, Triflow, etc.) would work just as well. I used new gray Scotchbrite to be sure there wasn't anything imbedded in the matrix that might scratch the new work.
Attached are some photos of how it turned out. Note that the hand grip area of the e-brake lever, and the cup for the shift lever, are still bright, while the other parts have been treated. I'm pleased with the way they turned out.
I still need to replate the door handles, window cranks, escutcheons, and a bunch of other small parts. Cost-wise, I think I'm going to try doing them at home rather than send them out.
And wrndln, I did the instrument panel so the grain runs horizontal. Not sure why other than it seemed logical to me, I don't think I found a reference.
Thanks for the pics, I talked again with my plater and he showed me his 'sample' chip and it looks like JayJay's pictures.
Mike
Was the original Butler finish done after plating or was the metal just left with a brushed finish before plating?
It was a process and worked in at each step in plating. Here's Ford's process:
