I removed the engine and transmission. The clutch spring wasn't broken but it was badly bent. The clutch spring support failed! I Found pieces of it throughout the transmission and engine. Found the pin in the oil sump. Not sure why it failed. The person I bought the car from said it just quit running.
I have installed new spring, spring support and pin. All purchased from Snyder's. I find that my stack is at 2 inches with the clutch fingers just touching the plate. It looked, from reading all the past threads, that I would have needed to adjust the fingers to get the 2 inch height. Any thoughts?
