Woodie1
I have several issues going on. We have a 1939 & I just replaced all wheel cylinders & the master. I have also replaced the 3 flex hoses. There was too much crud appearing at the wheel cylinders. My 1st problem is there isn't a brake pedal return spring. I bought one & can't figure where it should hook to. I looked in the parts book & it says the spring should be 17.3" long. The one I got is a lot shorter & doesn't look like the one in the book.
The next item is we have bled the brakes at least 10 times & the pedal still goes down about 4" leaving 3" to the floor. I can't see any leaks at the fittings. We have tried pumping the brake pedal slowly & holding it to the floor on the 3rd. pump & then opening the bleeder screw & looking for bubbles. We start at the passenger rear, then driver rear, then passenger front & driver front.
I've searched the Ford Barn for brakes & I can't find any clues to what we are doing wrong. I've included a couple shots of the frame where I think the spring should be. I think the speed o cable may be in the wrong spot.
