FlatheadTed
Something to be aware of .While doing a brake job ,I was holding the actuator wedge up while working the clevis arm I noticed a lumpy feel to the clevis moment ,I traced this to the end of the clevis rubbing on the inside of the king pin head .You can see in the shot were I ground it of .I put this down to repoped king pins not machined out enough .I also needed to put a slight bend on the king actuator Rod 1" from the top to get a smooth moment .
