Body mounting a Victoria
rer_239
L put body webbing on frame before splash apron does anything go on top of aprons before the body?
Thanks
Dick
Are the only 2 body blocks the ones at the very front of the cowl and spacers as needed?
Thanks
Dick
Hello rer 239, be extremely careful in aligning the doors as you are fastening the body to the cowl section. Once the roof is welded to the cowl section, there is no further opportunity to adjust the door opening width for a good door fit. Ed
Here are some pictures of my 190A restoration. The rubber pads on the bottom of the wood body rails rest directly on the running board splash aprons. When mounted, there should be 0.13" to 0.25" clearance between the body and the apron.
This thread could not come at a better time!
I have a barn find that was in pieces for at least 20 years. Avatar picture is from my first assembly to see where everything "landed".
Knowing the gap needed for the splash aprons a big help. Had too many rubber spacers under the wood. Thanks!
This is info I developed to mount my 190A onto its frame. The photo shows an original rubber pad attachment at a body bolt. This post is augments Post #8.
