Upon removing old graphite head gasket and comparing to new graphite gasket I see that the old gasket has shrunk in diameter around piston area; is this a result to torquing aluminum heads to 60lbs.? Also, one of the water passage ways in head gasket is much smaller than the passage way in the block; is this as it should be or should I enlarge opening in gasket?
