Old Henry
This was the inner distributor cap I replaced just in October 2015 with a new one like it from C&G. Notice how it is missing the button at the center for the rotor to run on.
This is the same inner cap bought from the same source, C&G, that has less than 10,000 miles on it that I just checked on as I was doing my 10,000 mile maintenance replacing the points on the distributor.
It already is missing that center button and several of the posts have cracks in the plastic holding them. You can see where the rotor blade is just rubbing on the bushing around where the button originally was.
As anyone knows who's done it, these inner distributor caps are an absolute pain where it hurts to replace. The entire sparkplug wire loom and conduits have to be removed from the engine to deal with pulling all of the wires from the old cap and getting them all in the right holes on the new cap and getting the outer cap to seat down onto the inner cap. I hate it and it is not supposed to be a part of the recommended 10,000 mile maintenance.
I'm hoping someone knows of a better inner cap that will last longer than these from C&G. Any ideas?
Also, the best rotors in case that makes a difference. I've been using this one from NAPA. It looks like the same one Mac's sells.
Is there a better one?
Parts Geek sells this one. It has its own button on the contact surface. Do you think it's any better?
This one from C&G looks worse to me:
