This is a tool we use quite a bit its a spot welder that welds a stud on the dent and you pull on the end like a pop rivet with the slide hammer. Also the blending clear ,Ted
Worked on my dent today, I used a heat gun then hit it with an air duster can turned upside down, it came out a little, I then hit the backside with a small rubber hammer and it popped out pretty even, almost unnoticeable.
Thanks for the all you suggestions.
