kd4lok
I like 20-50 but the important thing is to not use non-detergent. Oil is cheap compared to a rebuild, change it often.
I was told NOT to use detergent oil in engines without an oil filter. Now I'm confused.
IMO the only things non detergent oil are used for in my book is bicycle chains and chainsaw bars...theres a reason the dollar store used to sell it for $0.75 a qt...I was told NOT to use detergent oil in engines without an oil filter. Now I'm confused.
In trying to further explain the complexity of engine oil lubrication vs. "cheep" in #14:
1. "Cheep" is really a very critical mathematical, exponential growth function; and,
2. Model A engine wear, caused by not changing oil often enough .... increases far more when one is considered "cheep-cheep-cheep" as opposed to when one is considered just "cheep".
Hope this helps to partly resolve this Model A engine lubrication mystery.
I am having a struggle with which motor oil to use in my coupe engine today. It is completely rebuilt and we are adding the fluids to everything today. I would love to hear suggestions on which oil is working the best these days.
Thanks
iiiiii
According to the oil engineers, that have commented about what kind of oil the old cars should be using, additives and detergent are what they recommend.
You need additives especially to prevent the build up of acids. You know the stuff that leaves these cool patterns in the bottom of oil pans. I have personally seen a lot of them. The detergents keep the particles in suspension so they will come out when you change the oil. Some of these particles are smaller then what the filter can catch.
Also guys change the oil way too often. The 500 mile thing was in the 1920's when oil was poor quality and there were no additives. Oil needs to be changed when it dirty or out of additives. My guess is a few years or a few thousand miles. You would need to have the oil tested to know for sure. What we do know is your engine is way more likely to fail from being poorly built then wearing out. How many guys expect to get near the 50,000 mile mark on their engines??? Ya, you should expect 50,000 to 80,000 miles on a properly rebuilt engine, no filter and crappy roads cause that is what they got back in the day when the A was new.
BTW, keep in mind condensation occurs when the metal temp allows for the air to condensate on the inside of the metal. The happens often in places with humidity and wide temp variations. So you do not have to run the engine for them to get wet inside. Part of the same reason juice brakes fail.
Mike V Sez: No one has ever proved that non detergent oil is harmful to the A engine.
Mike, are you saying the sludge build up inside an engine that used ND oil isn't harmful?
