I agree, mine is on the 12V negative ground side.
Same
I've never been a fan of those things. They quite often result in problems down the road a few years with bad connections in an un necessary gizmo. Just pull off the battery cable. If its clean as it should be, its an easy thing to deal with.
Those things are popular with the model A crowd as that wire harness is hot all the time. Your 47 has a fuse , no? Sorry, I am not familiar with post war stuff
My 2 cents on which post to use for the battery disconnect. Think about when you disconnect the battery. You disconnect the ground first. That way you don't accidentally touch the hot cable to a ground source when disconnecting the hot cable with the ground still connected. JMO
Edit: but some sanctioning bodies specify that the hot side be used.
For NHRA compliance, use heavy-duty 1-gauge or 2-gauge welding cable for battery disconnect switches, especially with trunk-mounted batteries. The switch must be on the positive side, interrupting all electrical power, with the alternator wired to ensure the engine stops immediately when the switch is engaged
For Bonneville Land Speed Racing (SCTA rules), the battery disconnect switch must be installed on the positive side of the electrical system and act as a master cut-off for all electrical functions, including the alternator and ignition.
I don't really understand what you are saying in your first paragraph.
I do agree with the third and fourth paragraphs.
