Mr 42
Henrik is a master welding with his eyes shut
Kidding asid he "only" tacked the panel and then oxy acetylene welded it shut with proper protection.
Im planning a Magnum 5" axle with a monoleaf spring.
In the rear i have an idea to use airbags without cuting anything. It will be three four inches higher in the the rear when driving.
The rear axle is resting on the frame in this picture.
Running board closed up and finishwelded.
Henrik rustproofed the inside befor welding it closed
Floor ready for some primer and paint
This piece of iron will provide some motivation in the future i hope
59AB that was dissasembled 10-15 years ago by the previous owner. I got it for free since the main bearingcaps was lost. (more about that later).
At the time they fixed the valve seats/valves and put in new cam bearings.
Fatory reliving yes it was a truck engine.
The owner before me, sorted all the bolts, in small plastic containers. And most of it is still there.
The crank does not look good, this happened when it was standing to close to a car battery that was charged and the gas from the battery caused it to rust, i have to use some emery paper and do some measuring.
