Jack 34pu
As slow as it seems, I'm working on an AV8 28ccpu for a driver. I will be running the T5 trans mentioned in recent posts but i want the Banjo look under the rear of the pu. Winters has a non quick change version but it is over $3k. I don't have the equipment to machine anything so is the someone out there that can supply a modified original Banjo with moderm=n drum brakes that would be narrow enough for the 28pu? - For less that $3K?
Jack 34pu
Jack 34pu
