steve s
Bob,
IMO, the first big question is whether the motor/drivetrain truly vibrates too much, or, are normal vibrations being transmitted too much. I suspect it's the latter: tightening down the motor mounts too much is the surefire way to do this.
I think that if there were mass imbalances in one or more rotating parts, vibration should depend only on rpm; there is no reason for vibration to depend on acceleration/deceleration, or, for the motor/flywheel, whether the clutch is in or out.
Greatest bearing loads and dynamic unbalance vibration commonly occurs during decelerations because the compression strokes are occuring against relatively empty combustion chambers; normally, the fuel/air charge serves as a cushion reducing stress on bearings/rods (interestingly, even more so for high compression heads!). It's quite common for the rear view mirror on a Model A to be useless while backing down from speed.
The only possibility I'm not sure of is the U-joint issue; I would defer to a real mechanic on that but it seems to me it could behave differently between acceleration vs. deceleration loads. But, there's no reason to suspect the U-joint to get worse while your motor was being rebuilt, and every reason to suspect that the motor mounts might be differently snugged.
Loosen up those motor mounts--there may be a really easy fix in your future!
Steve
Steve
