That's what I said only in a different way, so re read my post again. Do this.... refit that fuse back in its holder and start disconnecting things, starting by disconnecting all the wires to the stop light switch and make sure they are separated from each other. How many wires are on that stop light switch ? Report back your findings.
Okay so here’s what I did.
Put fuse back into its spot.
Connected positive side cable to battery.
Disconnected the negative battery cable.
Placed one end of the circuit tester to the negative battery cable.
Placed the other end of the ciruit tester to the negative post of the battery
( circuit tester light came on )
I dissconected the headlight switch ( circuit tester light stayed on )
Dissconected the passenger side door light switch positive and negative wires one at a time ( circuit tester light stayed on )
Dissconected the driver side door light switch positive and negative wires one at a time ( circuit tester light turns off when I remover either one of those wires )
