Backing Plate Bolts
Dennis Pereira
When I removed my rear brake backing plates bolts they lacked cotters . I now know why they were the wrong nuts too tall to line up with the hole in the bolt .The nut on the right if the photo shows .
Good Morning...If you don't find them in your spare parts bins, then Burt's in Denver will most likely be able to supply you with reproduction or original nuts that will do the job. Ernie in Arizona
