30ccpickup
Just for grins and giggles after this much problem solving and no results, I might check the condition of the timing gear.
Check the copper strap that runs on the outside of the flat spring on the points (it is kind of U shaped). I had this same problem, the strap is too long on some points and will touch the case of the dist. causing all kinds of problems. My '29 Tudor had this problem when I purchased it, took me many hours to find, as soon as it got warm the missing and back fireing would start, let it get cool and everything was fine. All that was needed was to put a little bend in the strap with a needle nose and the problem was solved.
A vaccum guage connected to the intake while driving might help find the problem. If the needle starts to flicker at the same time the problem begins, then look for sticking valves. A can of Sea-Foam in the gas and another can in the oil might fix it.
Removed pop out, jumped to coil ,and test drove,did the same thing.No micro. stock points,tried known good distributor same thing. Thanks for the thoughts.When it starts to act up, try jiggleing the switch key. I had lots of problems with the low cost ignition switches that are sold by most venders. I now use the pop out look alike switche with good results. Its not a pop out switch but looks sort of like one from the instrument panel side. I had similiar problems with the so called modern points set up. Another thought is, are you running a micro filter , anywhere in the fuel system ? I had similar problems with micro fuel filters. The mesh is SOOOOOOO fine that very small sediment that would run through the system without problems would partially block the filter and restrict the flow, if i feathered the throttle just right I could make it home. many things can cause similar symptoms.
Hello Steve! No go tho! Good breakfast tho! How about coming over and visit, maybe you have a solution(s). We will be looking forward to your visit with the new wife.Whidbey is nice! ThanksI understand Don Diers had a good thought last Saturday at breakfast
Pluck
steve bring new wife stay at my place and help gary and i figure this thing out
