backfire
Would love to! Such a beautiful island in Puget Sound!
Might even bring a few "potatoes"!
Have you made a list of all the "combinations" of replacing this and that that you can think of?
Pluck
and then some! Have the whole club involved. With a lot of expertise.Looking forward to your visit in the Near future. Thanks.:)
A running engine requires Fuel, Air, and spark.
Spark - Sounds like you've all but ruled all of these things out parts wise, unless you have an intermittent ground, short, or open curcuit somewhere else like the terminal box, ammeter, or battery. Also could have a cracked or bad distributer body?
Fuel / Air. I suspect the problem lays in here somewhere. It sounds like fuel to the carb is verified ok and manifold leaks are ruled out (including carb to intake surface?) so that leaves a problem or blockage internally with the carb or a valve issue. I think you have ruled about all else out! :eek:
bttt, We may have found the problem and the solution. We will be getting back to you Friday Feb 8th with the answer. In the mean time, Keep on A-ing.:D
:rolleyes:Problem Solved! See new Thread on Feb 8th. Thanks for all the Ideas,thoughts and other remarks that came out. Its so much fun being a Parts Changer! And a Model A Owner.
