Found my vacuum leak! There is a small leak in the plug for the idle mixture adjustment hidden passage. previous owner had drilled it out and installed a new brass plug but it isn't air tight. What is the best way to fix this?
Found my vacuum leak! There is a small leak in the plug for the idle jet hidden passage. previous owner had drilled it out and installed a new brass plug but it isn't air tight. What is the best way to fix this?
Not being totally familiar with the drilled out plug you reference but JB Weld comes to mind or you could remove the brass plug and coat the threads with a fuel proof thread sealant.
