Herm -
If we wind-up with an un-equal stack of shims between both sides, is there a preference as to which side has the thicker stack ?
I seem to remember something about babbit Chevys favoring the thicker stack on the cam-side of the bearing ?
Just keep going from side to side, when shimming. Thickest pack first.
With .001 shim stock, you can put your bearings right where you want them.
I know what you are saying, Mr. Coupe. there was .008 on the cam side as you said, and .006 on the other side.
Most of the bearing books have .006 listed for both sides, and that is what we use for the 6 cylinders now.
The Chevy 4's use 32 on the mains, and rods use .006 with a filler plate which totals to 1/8.
Here are some pictures of the Chevy 4's, and 6's.
Dick, the .001 shim stock we get from McMaster-Carr., and we do cut, and punch our own on something like that.
Thanks
Herm.
KohnkeRebabbittingService.com
