B intake size
JtownJoe
I tried running a search for the correct size of the B intake, to have my A intake bored out, but I was unable to find it. Does anyone out there know what the correct size is or at least what the maximum safe size would be? Thanx, Joe in PA
I measured a B carb throttle bore last week and it was 1.3". I found a good reference online that said they used a 1 5/16" drill bit to bore the A manifold out. But I can not find it now to share with you. Sorry.
B intake size & process of enlarging the "A" manifold
Greetings,
I have some pictures on my website (address below) of the process with the drills sizes I use. It is a real simple process. The drill size is noted on one of the pictures.
Look for: Intake manifold enlargement under the Other Model A services area...click the link.
There are a number of pictures so it may take a little time to load. (1.78mb)
My website: www.durableperformance.net
Good Day!
Dave in MN
Re: B intake size & process of enlarging the "A" manifold
Thanx for the info Dave, I will take it to my local machinist who is doing some work for me to install my F-150 4 speed set up. Thanx again! Joe
