Mitch//pa
I noticed page 375 of the Service Bulletins shows 1 1/2 quarts also, must
be misprints.
Bob
is that info for the AA diff's ???
page 227 service bulletins shows 1.5 pints
be misprints.
Bob
diff capacity:
different info from different sources::
brattons 1.5 pints
snyders 2 qts
les red book 2-1/4 pints
service bulletins 1.5 pints
tams 1.5 qts
macs 1-1/2 to 2 qts
all this fun :: i always fill on a level surface till it trickles out the fill hole.. i never actually measured what went in
Someone here once wrote, I've just removed the drain plug & let it drip awhile, HOW do I get the oil back in that hole"? The DogX2
No dipstick needed, just remove the top plug and fill until it starts to trickle out. I would never let it get lower than 1/2" below the bottom of the fill plug hole.
NO! The bottom of the FILL hole, thet's the UPPER oneOne quart or ten quarts...does not matter, bottom of the drain hole, that's all you need to remember.
then youll be empty![]()
