one of the axles looks a little short!![]()
The gaskets come in a verity of sizes so you can get the stack down to within a few thousands. Speedways set has the following sizes included in their axle gasket kit:
•(2) - White gasket thickness - .003"
•(2) - Ivory gasket thickness - .005"
•(2) - Green gasket thickness - .007"
•(2) - Blue gasket thickness - .009"
VanPelt sells a BEST Gasket set, looks like it has the same size ranges.
Total of both sides determines bearing preload and the difference between them determines backlash. Everyone I know sets them by "feel" as to both preload and backlash.
Since you are going to need to remove the diff and axle shafts anyway spend some more $$ and install brake drum retainers. They are not expensive and they work.
Vern Tardell has them.
38v8...I think my axle housing are one directional.
I went back out and wiped down the gasket surface and there are gaskets on both housings. One broke when I took the housing off and this gasket measures .006. The gasket on the other housing is intact with the exception of a little piece missing at the outer edge of one of the bolt holes. I didn't remove this gasket so I can't measure it.
Many folks probably do set bearing preloads and backlash by feel. This is the way I did mine in 2013, and in 2015 that rear had a complete failure, and all that I could salvage from that mess were the two axle housings and the torque tube. I used measuring devices this spring to make those setting on my rebuilt rear, and I plan to do any future rebuilds this way rather than by feel.
Capt, good job on disassembly! A few comments.....
1. 37 to 40 axle housings are normally one directional, although I have seen them swapped around by some hotroders to give some funky spring possitions.
2. In one of your earlier pictures, taken of the rear banjo center, I noticed non standard ford bolts with lock washers bolting the axle housings bell ends to the banjo housing. These standard Ford bolts are special to help in sealing as are the female threaded holes on the banjo housing. I would suggest getting the original type bolts to use there.
3. Many folks probably do set bearing preloads and backlash by feel. This is the way I did mine in 2013, and in 2015 that rear had a complete failure, and all that I could salvage from that mess were the two axle housings and the torque tube. I used measuring devices this spring to make those setting on my rebuilt rear, and I plan to do any future rebuilds this way rather than by feel.
4. When you measure those shim gaskets that were between the housing bells and the banjo housing, keep in mind that those gaskest get compressed when all bolts are final torqued. So for example, if you measure the thickness of an old/used gasket @ 0.007" it most likely started out at something like 0.008". Just sayin'... you would probably not be correct in putting a new 0.008" gasket back in.
5. Also, if the carrier bearings and their cups look good and you decide to reuse them, keep in mind there has been some wear on those bearings and putting the rear back together with original shim/gasket thickness will more than likely not give you the correct preload, IMO.
6. While you have things this far apart, I would strongly suggest replacing all three rear seals, two in the small ends of axle housings and one in the front of the torque tube.Code:
I believe there were some other things I noted as I reread this entire post earlier today, but when suffering from CRS, I could only recall the 6 things. If and when I remember more, I will just add them to this list.
ps...keep up the good work Capt, you did well today getting all this done, I assume working alone?You are much faster at this than I am, but than you might be a bit younger and still full of pep and vigor
This is going to get me in BIG trouble with JM (and who knows who else!!!), but just couldn't resist! Just doesn't say much for your "feel" ability JM!!!
I've never seen a failure based on this factor, but would guess it is possible. We set up a LOT of race environment banjos and always by feel. But if you are uneasy with that by all means measure it. My QC is even set up by feel, myself I trust that far more that instrument reading in this limited application.
On 9 inch and 8.8 inch it is totally by very careful precision measuring, but not on the banjo. This is just me, not trying to persuade anyone, you should do what you are comfortable with.
Don't spoil my chance at getting another tool! "Honey, I NEED this tool in order that we don't break down making it necessary for you to push the car"
Regarding seals, I was planning on replacing the axle and hub seals...didn't give much thought to the seal in the torque tube. I wasn't planning on pulling the torque tube off...is this seal you're talking about at the trans end of the torque tube?![]()
