JM 35 Sedan
Another wakeup call, if you will.......before you run out and buy those drum retainers, and hastily bolt them in place, with a sigh of relief, it might be a good idea to pull those drums first, and check the axles for stress cracks/fractures, etc., condition of key ways and keys, condition of taper on axles, and drum hubs, and condition of threads on axles and axle nuts. Then if all looks good in those areas, clean and reseat those tapers using some laping compound as ford38v8 mentioned in one of his recent posts. Give those tapers a final cleaning, DO NOT put any type of lube on those clean dry tapers, put good keys in their proper location, reinstall the drums, and torque the axle nuts to the correct specification after making damn sure you have axle nuts of the correct material and heat treat hardness.
ps....I am sure some who read this, who normally like to take shortcuts, and do things quickly, will probably think this is unnecessary, or does not apply to them.
