I don't understand why people don't buy an AF meter ?? There not very expensive and can solve allot of problems in a fraction of a second!!!!!
From what I could determine about the unit it sells for about $250 and does not come with the sensor or the weld in bung.with this unit is it easy to swap between vehicles?
Would like to be able to check a couple of flathead setups with this.
Thanks
Phil NZ
I have the Innovate unit linked above, it is very interesting to watch how the carb responds under different conditions.
You have to weld a bung on the exhaust, preferably up near the manifold. Hook up power and a thick cable between the O2 sensor and the display head. Can be hooked up to a laptop to capture data while driving (see below). I'd say you could switch it between cars in less that half an hour.
Only one bung on one side required.How do you get on then with twin pipes does it require a bung at each one.?
Appreciate your info as want to be sure to get the right one and all bits in one hit.
Phil NZ
