Has anyone used one of these? It has two gauges, one for RPM (0-6,000)/Distributor (0-30) and the other for vacuum. I think it was made by Durst Electric in Sydney.
I would just clean it up a bit and check it out. I am assuming it isnt being used now and may never work again. Plug er in a see if it will motor.
The ignition board is just a coil ( simular to the auto coil) and oftens fire a small neon in the dial to check firing sequence.
Becarefull with the tubes and capacitors they can hurt ya......
300v b+ for the tubes and old electrolytic caps thats an accident waiting to happen !!!!
Caps that has been out of use for long time should be either slowly aplied the voltage by using a variac or replaced.
Slamming them with full voltage isnt a great idee...
They may explode sending their guts around the room...
