RalphM
So I just tore down the 1924 transmission, cleaned it and put it back together. Only one problem the new clutch disc set Had an odd amount of plates. When I took the transmission apart, the round inner tooth disc was the first one to go in.
When I tried duplicating that with the replacement set, I ended up with one outer tooth disc left over. So I took it back back apart, and I put the outer disk first and it came out even at the end.
Is this wrong or will it work OK?
I forgot to add I measured the old clutch pack when it came out altogether. Measured 1.190 inches, the new pack altogether measured 1.100 inches.
Thanks!
Ralph
Thanks!
Ralph
